ironblock ls1
Old Aug 20, 2009 | 10:19 AM
  #21
454navyss's Avatar
i think the stock 5.3 bore is 3.78 from what we looked up in the scat book
Old Aug 20, 2009 | 10:20 AM
  #22
454navyss's Avatar
and i dont plan on having him do the work on it, i'll take it to someone who has done work on LS motors
Old Aug 20, 2009 | 10:23 AM
  #23
Bluchevypick's Avatar
Yeah that sounds about right.
Old Aug 21, 2009 | 12:20 AM
  #24
454navyss's Avatar
i talked to an engine builder in dallas today, he said he will vat and magnaflux the block, bore and deck it, install cam bearings and freeze plugs, polish the cam i have (tr224), mill the heads .030 for $250 then after i get the short block assembled he will balance the rotating assembly for another $200
Old Aug 21, 2009 | 02:01 AM
  #25
StrokerAce03's Avatar
Stock 5.3 bore is 3.775 and stock LS1 bore is 3.898; so you'd need to have it bored .123.
Old Aug 21, 2009 | 03:10 AM
  #26
Faze2183's Avatar
could a 5.3 be turned into a 383? if so how many quarts of oil n such would you need?
Old Aug 21, 2009 | 06:40 AM
  #27
LS1TRUCKGUY's Avatar
as long as you have the stock oil pan, 6 quarts.
Old Aug 21, 2009 | 09:31 AM
  #28
Coban's Avatar
I'm a bit puzzled by this question. You are talking about major engine modifications and you are worried about the amount of oil required? One step at a time.
Please explain this reasoning, because I must be missing something.
Old Aug 21, 2009 | 09:57 AM
  #29
454navyss's Avatar
the oil pan determines how much oil the engine needs not the displacement
Old Aug 22, 2009 | 04:15 AM
  #30
Faze2183's Avatar
sorry it was late when i posted that question...
ive been wanting todo a iron block 5.7 for some time now... but my main question is can the 5.3 turned into a 383? or should i just stick to the idea of making it to the LS6 specs?
i know whatever oil pan i use will be how much oil is used, which id plan on just using the stock pan that is on there now...
BigKID
Jul 11, 2024 05:28 PM
thompson
Sep 30, 2015 09:48 AM
maxspeed05V
Sep 23, 2015 10:48 AM
Dawas
Sep 20, 2015 12:00 PM
FormulaZR
Sep 14, 2015 05:23 PM
