ironblock ls1
here's the deal. my truck is starting to smoke a little on start up, probably the vavle guides leaking but with 159K in the truck im a little worried about the rings and bearings in the bottom end so im thinking about building another motor to drop in when mine goes.
what is the difference between a 5.3 bottom end and an ls1 bottom end? from what i can tell just the bore is different. if i bore a 5.3 block to a 5.7 with some slightly domed pistons (or should i go with a stock 5.7 piston?), 706 heads milled .030", tr224 cam, and full boltons what should i expect? is it worth the time and money to build a 5.7 or should i stay with a stock displacement? also, i will be keeping the stock intake if it matters.
or should i build a 6.0 with the stock bottom end, same tr224 cam and milled 706s?
keep in mind this is still going to be my daily driver and i do drive quite a bit so i dont want to sacrafice too much gas mileage or get too radical, i will be towing with the truck as well as attending track days....i use my truck for everything
what junk yard has the engines for like $85? im assuming 5.3s are easier to find than 6.0s out there?
i already have the heads, cam and pretty much everything to swap them to my engine, i just want a fresh bottom end too
i built an ironblock 5.7... machine work cost me 380 total... picked up a 4.8 for 300... but the crank i had to buy from a buddy and he sold that to me for about 75 and then the pistons i bought for 40 from a guy down the road from me...
