Interesting spark retard limit findings
#21
This interesting (just learning HPTuners and want to
mess spark around). So the spark retard limit is the
"drop-to" limit and not a "drop-by" limit? Is that the
way you guys have it mapped out?
#23
#24
Originally Posted by StupidFast
Hey Black Blown, did the timing advice help out? I read you can still only get 16 degress. What is your a/f ratio at?
Interesting thing though, it can't handle 20 degrees in second or third gear, and can only handle 16 in third gear. It seems load has more of a bearing on the timing it can take than IAT. Example...if I'm cruising at 70mph with near ambient IAT's and punch it, It gets 20 degrees of timing until IAT reaches a certain point. It can't handle 20 degrees in Third gear.
So the only time the 20-15 table works is when I'm racing from a stop. Right now, I have my 15 degres flat across tune in. When I go to the track or to the street races, I'll load the 20-15 table.
My A/F is 12-1 flat. I think the thing thats killing me is the 91 octane premium here.
#25
Your 5.3 4wd would certainly be under a greater load than my 6.0 2wd for sure. There are ceratinly differences in my old setup than yours and the octane level might be the biggest. Well, I do hope that you can tell a noticeable difference.
#26
#27
I think maybe this relates to the speed of the run-up in RPM?
Things like the airflow and the spark advance that depend on
"load" or MAF value will always "be a little behind" when you
are spinning up fast in 1st, while 3rd gear is closer to steady-
state and the "real" advance the engine can tolerate under
continuous operation at fixed RPM.
Originally Posted by Black Blown 02
Heres the latest. Got it up to 20 degrees in 1st gear, 19 down to 17 in second, and 17 to 15 in 3rd. Did this with IAT vs MAP like you said. First and second gear seen a little stronger now for sure.
#29
Originally Posted by Jimmyz
Call John Rovner if you've not got this worked out. He's very good.
GrooveCityZ71
Aug 31, 2015 12:05 PM
smokeshow
Aug 23, 2015 08:23 PM
Fast86z
Aug 23, 2015 12:35 AM
Mr. Chainsaw
Aug 5, 2015 07:54 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
