intake question
Old Jan 19, 2011 | 08:35 PM
Lowered 93Z's Avatar
Default intake question
I have a intake from a 06 lh6 that's a 87mm with the intake what would it take to make it work on my 04 5.3?
Old Jan 19, 2011 | 09:12 PM
AndysC3's Avatar
as long as its cathedral port intake it should bolt up. and a 4 bolt tb. are you dbc or dbw?
Old Jan 20, 2011 | 10:16 AM
I am dbw and so is the intake off the lh6 what's the worst case I need to swap injectors?
Old Jan 20, 2011 | 10:29 AM
AndysC3's Avatar
I would pick up a set of 42# just in case. I believe the ones on the intake are an ev6 injector clip and your truck has a ev1. Also, if your going to use the tb on the intake I believe you will need the Dr. x harness. you can do a search on here to find out more info on it. I'm sorry that I cant be of too much help, I'm still learning alot myself. Maybe someone with a little more experience with the swap will chime in. I hope you get it figured out.
Old Jan 20, 2011 | 10:48 AM
Thanks for all the input its been a big help I am going to look into the wiring and injectors
Old Jan 20, 2011 | 12:29 PM
andrew383's Avatar
traveling mod
There are tons of threads that cover this topic...In fact there are 3 on the first page of this section
The_W
Oct 28, 2015 09:00 PM
Denali08
Aug 9, 2015 04:34 PM
USMCvet0311
Aug 1, 2015 07:45 AM
blackdc3
Jul 7, 2015 07:52 PM
Hmguyton
Jul 7, 2015 03:29 PM
