Intake manifold option for cable-throttle guys
Old Oct 4, 2006 | 06:02 AM
  #21
ZR1 DREAMING's Avatar
Originally Posted by Scream
Maybe I'm just missing something, but I don't see where it says in any of that what style injectors the manifold will take. Will I still be able to use the Multec II truck injectors, or do you have to switch over to the F-car stuff?
Well I beleive Richard said you can space the rails out and utilize the truck injectors. Which is what I plan on doing, I have the Racetronix Multitec IIs also.
Old Oct 4, 2006 | 05:43 PM
  #22
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
If oyu want to run the "taller" truck injectors all that is needed is to build your own fuel ril spacers. I will be running one of these for my nitrous to spool the turbo out of the hole:
It is a wilson manifolds plate for 4150 flange with burst panels good for a 350 shot
Wilson Manifolds can port the vic jr intakes if you want that extra bump.
You can use a carb style round filter as long as you have an IAT sensor somewhere in there. The IAC will have to be rescaled to accomodate the different air flow of the edelbrock IAC system. The throttle blades on teh 4 barrel are progressive. Two open up to 90*s then the other two start to open up. There may be a spacing issue with the throttle linkage and the fuel rail with truck style injectors but I have mocked it up yet ot know for sure. Since I will be running the Nitrous ProFlow plate system I wont but someone who isnt may, so Ill mock it up that way to make sure.
byrne_06
Apr 29, 2017 02:19 PM
OHsixLS3
Dec 27, 2016 09:30 AM
fat tony157
Jul 16, 2015 12:35 PM
Hmguyton
Jul 7, 2015 03:29 PM
Black-Syde
Jul 6, 2015 02:12 PM
