Intake manifold option for cable-throttle guys
Old Oct 3, 2006 | 10:49 AM
im very intrerested in this too, its a great option and i cant remember where but someone posted up where to buy the elbow to fit on top and put a normally facing TB on it... what kind of injectors would you need? i assume car injectors. also, would you need to change fuel rails, if so, what is there to do about the return style fuel delivery that came with our trucks opposed to the returnless that most everyone else has (i dont know when it switched over)
Old Oct 3, 2006 | 10:55 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Search button is your friend ALL of that is covered in the threads linked in this one.
intakeelbows.com has the elbow to mount the tb in the "stock" location
Old Oct 3, 2006 | 12:35 PM
eff the search button!!!! someone just answer my return/returnless question
ill post this for myself before anyone else gets me
Old Oct 3, 2006 | 01:18 PM
goshawk23's Avatar
Truck addict
scream, i plan on doing this swap sometime over the winter. i intend on using the 90 degree bend with a 85mm or 90mm throttle body. i'm probably going to have a custom bracket made to accept the cable. it's all talk but thats my plans.
Old Oct 3, 2006 | 03:02 PM
1slow01Z71's Avatar
If you are going to go the elbow route this is how I would do it
Everyone ignore Soon2beSpooled from now on so he uses the search button
Old Oct 3, 2006 | 04:17 PM
Scream's Avatar
MOOBIES Moderator
Maybe I'm just missing something, but I don't see where it says in any of that what style injectors the manifold will take. Will I still be able to use the Multec II truck injectors, or do you have to switch over to the F-car stuff?
Old Oct 3, 2006 | 08:00 PM
Rhino79's Avatar
9 Second Club
It uses the car injectors. I have researched and found out cause we'll probably do the setup on the Wood Hauler's 408 very soon. The Carb hat was the only thing I was still looking for. But if you wanted to run speed density couldn't you just use a carb style air cleaner and plumb an IAT sensor in it? Just a thought.
Old Oct 3, 2006 | 08:04 PM
Sport Side's Avatar
More importantly, where does the nitrous go?
Old Oct 3, 2006 | 08:08 PM
Rhino79's Avatar
9 Second Club
Use a carb plate setup.
Old Oct 3, 2006 | 09:52 PM
litreddevil's Avatar
Banned
Question
i don't know were in FL you are but call cnc cylinder heads penelope FL they has some good info
