Intake Install problems
Old Apr 28, 2009 | 04:18 PM
Bad_Apple's Avatar
Default Intake Install problems
I'm having trouble clearing for my Fast 90 intake its hitting my powersteering pump bracket. I've got the L92 waterpump, Speartech idler bracket. how do yall get the bracket to clear the TB its about 1in. off??
Thanks
Old Apr 28, 2009 | 06:18 PM
silveradokidd_4518's Avatar
have to cut the bracket if its the one i think you are talking about
Old Apr 29, 2009 | 11:42 AM
Bad_Apple's Avatar
What kind of Bracket do I need to order or get??? Or does anybody have any pics of a cutt or modified bracket??
Thanks
Old Apr 29, 2009 | 12:21 PM
using the search really helps some times...
this is for an LS6 but its the same set up
https://www.performancetrucks.net/fo...d.php?t=359987
Old Apr 29, 2009 | 03:34 PM
krambo's Avatar
You'll need to cut the bracket to fit. i also ended up trimming that vac port near the bracket for good measure. Couple of pics:
Old Apr 30, 2009 | 12:55 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
^^^Much more helpful than another "search button" comment.....
Old Apr 30, 2009 | 09:18 AM
Bad_Apple's Avatar
Appreciate it Krambo... Thats what I've been looking for.
thanks
Now I'm running into problems with the spacers for the Procharger bracket not clearing the Idler pulley i'm running the speartech bracket. Does anybody know a smaller pulley I could run on the idler pulley that would be spaced right and clear??
Old Apr 30, 2009 | 01:31 PM
krambo's Avatar
Well actually i am running a Corvette C5 idler and used washers to space it out. I needed the small pulley to clear the water neck on the WP. Not sure if this is what you mean or not.
The_W
Oct 28, 2015 09:00 PM
Slammed96
Jul 27, 2015 07:22 AM
Ammadien
Jul 22, 2015 08:50 PM
lxcoupe
Jul 21, 2015 02:12 AM
Suburban2500
Jul 14, 2015 02:10 AM
