Intake help
Old Jul 31, 2014 | 10:03 PM
GRRR65GTO's Avatar
Originally Posted by gamble686
Planning on boost or spray? If not that pump is most likely over kill. The 320/340 options out there won't require the extra cost and will support around 750hp and is about $100 cheaper than 400.
Just sayin but I got my walbro 400 for like $120 shipped, you just gotta look in the right place i guess
Originally Posted by moneypitt
I might do up to a 250 shot, I don't know if I will do it but I don't want to have to redo the fuel pump if I decide to.
Not sayin you have to do the separate regulator and 400 but you know that you will have enough fuel and that you can adjust it to what your needs are, the aeromotive regulator I got was only like $110 from summit I think
Old Jul 31, 2014 | 10:07 PM
Moneypitt's Avatar
Originally Posted by GREENSIERRA
my stealth 340 pump over powered my stock fuel pressure regulator FYI
I have seen posts saying that can be a problem, I will probably just go with a Aeromotive A1000 Injected Bypass Regulator. And then install a Walbro 400, it seems all the newer intakes are return less anyway.
Old Jul 31, 2014 | 10:12 PM
Moneypitt's Avatar
I am not too worried about the cost, I have about a $12,000.00 budget to work with for the motor and trans. I would rather be covered and not need it than have to redo it.
Old Aug 1, 2014 | 11:47 AM
GRRR65GTO's Avatar
Oh it sounded like you kinda had a budget. Yeah a 400 i mean if really wanted to plan for the future a 450 and a regulator is the way to go
Old Aug 1, 2014 | 02:53 PM
Moneypitt's Avatar
Ok, thanks for the help. All this gas stuff is new to me, I have my duramax set up for racing but this is my first gas motor.
chvy=power
Oct 20, 2015 09:08 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
turbo truck
Sep 2, 2015 09:58 PM
lxcoupe
Sep 2, 2015 12:58 AM
