intake duration
Old Mar 14, 2005 | 06:30 PM
BigTex's Avatar
I'd like to hear whitt1s explanation on that as well. -EDIT- I was going to type up a rebuttal, but after re-reading his statement, I'm going to hold off until I see a reply. I think the wording is deceptive.
Old Mar 14, 2005 | 06:37 PM
2003blue5.7's Avatar
is it safe to say that a tr220 is a good street cam for a truck driven on the street "only in the summer" and make dam strong power from like 2500 to 6000?
Old Mar 15, 2005 | 12:34 AM
moregrip's Avatar
what a rush!
it would be nice to talk about this some more and come to a consensus, but it looks like we might not.
Old Mar 15, 2005 | 12:52 AM
Intake duration is just part of the equation the opening point of the exhaust valve will have a greater effect on powerband than anything other variable as it determines lobe separation and valve overlap.Sorry for not answering sooner I had to go out of town saturday.If you look at the exhaust duration and lobe separation you can compare cams from the same manufacturer to predict which one will produce power at a lower rpm.
Old Mar 15, 2005 | 05:02 AM
Sport Side's Avatar
Is it the exhaust lobe, or the exhaust system as a whole?
Old Mar 15, 2005 | 07:42 AM
marc_w's Avatar
Talking about a 'hit' down low -- my little stick DEFINITELY has a wake-up-call in the 1,700rpm range. Even locked up in 4th and OD, down in those low RPM's, the power increase is very apparent.
Old Mar 15, 2005 | 01:35 PM
Sport Side's Avatar
Whitt, could you explain a bit more?
The intake side dictates powerband. Choosing the correct combo of intake vs exhaust will net you the most power in that range. An effective exhaust as a whole will hold your power curve out further past peak.
I can't see how the exhaust lobe dictates powerband. If so, then the powerband would change with a swap of exhaust primary lengths. I don't recall gaining rpm peak w/ my long tubes. However, intake manifold runner lengths can change your peak. That's why these 3.62 stroked ls1's seem to all reach a 6200-6400 rpm peak. 15'' manifold.
I look at the intake lobe vs lsa.
With the same exhaust system, excluding the lobe.
x-e
intake lobe-220 on a 112 - 6000rpm
intake lobe-224 on a 112 - 6200rpm
If the exhaust lobe is paired correctly, you will make more power within that range.
Old Mar 15, 2005 | 03:11 PM
Moving the exhaust openings determines the point that the combustion chamber is most efficently scavenged.Savenging is a product of exhaust pulses combining to suck the unburned mixtures from the chambers a kind of back side supercharging effect.
Old Mar 15, 2005 | 03:15 PM
moregrip's Avatar
what a rush!
now this discussion is getting good,
BigTex, whats your take?
Old Mar 15, 2005 | 03:44 PM
Sport Side's Avatar
Geoff @ Thunder
To let everyone in on a big secret about reverse splits: As soon as you open the exhaust valve on the power stroke of a 4-cycle engine you aren't going to get any more useful force to push the piston down with. The catch to all of this is that there is a balancing act between taking energy to push the piston down and taking that same energy to push the exhaust out of the pipes to scavange the cylinder. A reverse split does not make torque or horsepower in a different RPM spot than a conventional cam assuming all other valve events besides exhaust opening, such as intake opening, intake closing, exhaust closing, overlap stay the same. The only affect of the reverse split if all of the other valve events are optimized is that you will have a later exhaust opening point which will delay blowing the cylinder pressure out of the exhaust pipes. Will this make more power? Again it depends if the exhaust system is up to the task of properly scavanging. We have tested all of this and know it works.
I underlined that one piece, because he was talking about reverse splits. How does this relate? The underlined part shows that given the same intake lobes but different exhaust lobes, the power range does not change, but the curve does.
I'm still not catching on, to how the exhaust lobe determines rpm range.
