intake duration
Old Mar 11, 2005 | 11:14 PM
moregrip's Avatar
what a rush!
Default intake duration
what approx intake duration would you say is required to get a big HP hit at 3000rpm
Old Mar 11, 2005 | 11:22 PM
About 220 degrees on the exhaust side.The exhaust duration has more to do with where the power curve kicks in and the intake duration has more to do with the power level.
Old Mar 11, 2005 | 11:31 PM
moregrip's Avatar
what a rush!
thanks whitt1, can you explain this a little more or link me
Old Mar 12, 2005 | 01:40 AM
Deckhand's Avatar
with my 219/228 i can feel a pretty good power "hit" around 3500ish when im just messing around like 1/2-3/4 throttle. At wot, i cant really feel the ramp.
Old Mar 12, 2005 | 11:59 AM
moregrip's Avatar
what a rush!
bump
Old Mar 14, 2005 | 12:49 AM
moregrip's Avatar
what a rush!
bump one more time, just wondeing if you could explain this a little more?
I'm guessing this statement is LSx specific
Old Mar 14, 2005 | 08:01 AM
L-EATER's Avatar
11 Second Truck Club
You aren't going to get "big hp" at such a low rpm. Hp is a function of rpm and the big numbers come with rpm. I notice you say "hit" so do you mean you want it to start pulling there, or you want it to already be strong there? If you want to mximize power at 3000, I would say stay small, like somewhere in the 216 to 220 range.
Old Mar 14, 2005 | 08:22 AM
marc_w's Avatar
I always thought the intake portrayed where the powerband will be...
I'll have to double check on that thought.
I was thinking about 216-218* in a 6.0.
The 216's are supposed to start making good power at 2,500. My 220, was getting healthy at 3,500 - but really hit at 4,000.
Old Mar 14, 2005 | 05:40 PM
moregrip's Avatar
what a rush!
define hit? 1. cruising in OD on the hwy @ approx 75ish, between 2200-2400rpm. Punch it, 4-3 downshift occurs, thats where I want the power to be, but not just starting there, but not much lower than that either, thats approx between 3000-3500 rpm, depending on TP.
don't really want to rev much higher than 6300 rpm.
I under stand that hp is the application of tq at higher rpm.
Old Mar 14, 2005 | 05:41 PM
moregrip's Avatar
what a rush!
I was told intake as well, however whitt1 says exhaust, just want the straight dope
