installing a pro-flo intake, need pics and some help
Kinda lost as to where everything needs to go on the intake. Anyone have any detailed pictures or advise? Trying to figure out where the sensors and vaccum lines run to
If it's like my Holley high ram intake basically tap and put fittings where you like. Doesn't really matter as long as the right sensors see what they need to see. Tap the back for your brake booster I also run my map sensor in the back (high ram has the provisions there) and for the evap tap the bottom
One thing I would strongly suggest is to center the ports with the intake runners. They have a bad design when they cast them and they dont exactly line up properly. I ended up sticking my cell phone in the plenum and taking pics of the left and right ports to center it the best I could. I did a thread let me find it.
I only hooked up the MAP sensor to the passenger side location, the brake booster to the rear pipe thread (If I remember correctly, I had to tap it), and tapped off the rest of the vacuum lines. I will get pics later.
