installing a pro-flo intake, need pics and some help
Old Jan 30, 2014 | 01:06 PM
2doorfury's Avatar
Default installing a pro-flo intake, need pics and some help
Kinda lost as to where everything needs to go on the intake. Anyone have any detailed pictures or advise? Trying to figure out where the sensors and vaccum lines run to
Old Jan 30, 2014 | 05:23 PM
Three6GMC's Avatar
If it's like my Holley high ram intake basically tap and put fittings where you like. Doesn't really matter as long as the right sensors see what they need to see. Tap the back for your brake booster I also run my map sensor in the back (high ram has the provisions there) and for the evap tap the bottom
Old Jan 30, 2014 | 09:15 PM
2doorfury's Avatar
I didnt even notice the provisons. Thanks! Do you happen to have pictures?
Old Jan 31, 2014 | 12:47 PM
2doorfury's Avatar
Bump.
Old Jan 31, 2014 | 12:48 PM
2doorfury's Avatar
Bump. Anyone with build pics using this intake?
Old Jan 31, 2014 | 05:53 PM
Gadgetized's Avatar
What exactly do you want pics of?
Old Jan 31, 2014 | 05:59 PM
Gadgetized's Avatar
One thing I would strongly suggest is to center the ports with the intake runners. They have a bad design when they cast them and they dont exactly line up properly. I ended up sticking my cell phone in the plenum and taking pics of the left and right ports to center it the best I could. I did a thread let me find it.
Old Jan 31, 2014 | 06:02 PM
Gadgetized's Avatar
https://www.performancetrucks.net/fo...-issue-521821/
I will clean it up before spring.
Old Jan 31, 2014 | 06:52 PM
2doorfury's Avatar
I'm looking for pics of everything hooked up. Trying to get a idea where all the sensors need to go
Old Jan 31, 2014 | 09:04 PM
Gadgetized's Avatar
I only hooked up the MAP sensor to the passenger side location, the brake booster to the rear pipe thread (If I remember correctly, I had to tap it), and tapped off the rest of the vacuum lines. I will get pics later.
