Installing heads how to torque down rocker arms
Old Sep 18, 2006 | 03:06 PM
Default Installing heads how to torque down rocker arms
I am installing Patriot stage2 heads on the 6.0 (finally) I was wondering what is the correct way to torque down the rocker arms. I did a search and it said 23 ft lbs , rotate 90 ,do this three times? I think the lifters were new. Mine are being reused and should have oil in them . Since they have oil already are they pre loaded? Just trying to clear a few things up before I start. Also should I use blue or red Loc-Tite? Thanks
Danny
Old Sep 18, 2006 | 03:18 PM
LesPaul's Avatar
i think that the 23 ft and rotate 90 is to install the heads themselves.... your going to have to find TDC and tq down the intake rockers on numbers 1 3 4 and 5 cylndrs. and exhaust on 1 2 7 8 cylinders all at 22 ft/pounds then turn crank full circle and tighten 2 6 7 and 8 intake and 3 4 5 6 exhaust also at 22 ft
Old Sep 18, 2006 | 03:29 PM
You basically want to torque them when the lifter is not under the load of the vavle spring (valve in opened position). You want to torque it to 22ft lbs when the valve is fully closed.
Jim
Old Sep 18, 2006 | 03:33 PM
LesPaul's Avatar
oh... you might wanna put some assembly lube on the pushrods too. and i dont think you should use loc tite at all.
Old Sep 19, 2006 | 10:59 AM
I think its the same set up as the Vettes www.ls1howto.com
The_W
Oct 28, 2015 09:00 PM
Kaldar
Jul 27, 2015 06:42 PM
Ketis
Jul 23, 2015 12:37 PM
maxspeed05V
Jul 19, 2015 07:08 PM
N/ALS1
11
Jul 13, 2015 10:56 PM
