Installed Vig 2800 and "check engine oil level" light came on.
Old May 9, 2005 | 06:07 PM
FILE's Avatar
Default Installed Vig 2800 and "check engine oil level" light came on.
Right after getting of the lift, the light light came on. I am very connfused. How is this related to changing my stall. I have resetted my pcm and reflashed it and it wont go away. Please help..
Old May 9, 2005 | 06:23 PM
XLR8NSS's Avatar
Adkoonerstrator
Turn the key to "on" and push the gas pedal all the way down three times. Does that clear it?
Maybe that info for the oil light comes from the BCM or something.
Old May 9, 2005 | 06:28 PM
shandy294's Avatar
I can't see any connection between the two.
Old May 9, 2005 | 06:45 PM
FILE's Avatar
Ok tried that and it won't clear it. I checked oil level and and for signs that it's leaking and everything seems good. This is really freaking me out. Any other suggestions?
Old May 9, 2005 | 06:47 PM
XLR8NSS's Avatar
Adkoonerstrator
Did a wire going to the oil level sensor or the sensor itself on the passenger side of the oil pan get damaged while messing with the trans or exhaust? That is my next guess.
Old May 9, 2005 | 06:52 PM
budhayes3's Avatar
PT's Slowest Truck
I was thinking the same thing...maybe the connector to the sensor got knocked off or a wire got pinched. Do you think that it's possible that the sensor got stuck from tilting the engine when you removed the trans?
Old May 9, 2005 | 07:56 PM
jerome's Avatar
its actually four times push the gas pedal i think...and that resets the oil percentage to 100% if you have the driver information console thing w/ the steering wheel buttons. and youve probably done this already, but did you check the dipstick to see if your oil is actually low?
Old May 9, 2005 | 07:57 PM
XLR8NSS's Avatar
Adkoonerstrator
Maybe it's changed on newer trucks but, all the GM's I've owned in the past including my current 2000 it is only 3 hits of the gas pedal.
Old May 9, 2005 | 08:36 PM
FILE's Avatar
OK... guys.. I crawled under the truck only to find out they did not connect the oil level sensor back. I put back in and it was gone when I turned on my truck. Thanks..
Old May 10, 2005 | 12:00 AM
How does it feel?.....Juans truck wont hook 1,2,3
ARC
57
Feb 21, 2022 10:54 AM
tweeder
Sep 18, 2015 11:02 PM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
Ferocity02
Jul 17, 2015 07:05 PM
