Installed Vig 2800 and "check engine oil level" light came on.
Right after getting of the lift, the light light came on. I am very connfused. How is this related to changing my stall. I have resetted my pcm and reflashed it and it wont go away. Please help..
Originally Posted by XLR8NSS
Turn the key to "on" and push the gas pedal all the way down three times. Does that clear it?
Maybe that info for the oil light comes from the BCM or something.
Did a wire going to the oil level sensor or the sensor itself on the passenger side of the oil pan get damaged while messing with the trans or exhaust? That is my next guess.
its actually four times push the gas pedal i think...and that resets the oil percentage to 100% if you have the driver information console thing w/ the steering wheel buttons. and youve probably done this already, but did you check the dipstick to see if your oil is actually low?
Originally Posted by Tiburon
OK... guys.. I crawled under the truck only to find out they did not connect the oil level sensor back. I put back in and it was gone when I turned on my truck. Thanks..
ARC
57
Feb 21, 2022 10:54 AM
tweeder
Sep 18, 2015 11:02 PM
bsgiffor
Jul 19, 2015 11:14 AM
Ferocity02
Jul 17, 2015 07:05 PM
