Installed an Eaton LImited Slip and have a question
Old Aug 28, 2003 | 09:58 PM
EricB's Avatar
Default Installed an Eaton LImited Slip and have a question
I was told that you will lose et after you install an Eaton. Is this true? I only know of two guys in my area that have them and they said that they did loose 2 tenths after installing just the Eaton. Just wanted to know since i just put mine in.....
Old Aug 28, 2003 | 10:25 PM
Hit Man X's Avatar
Default Re: Installed an Eaton LImited Slip and have a question
Ummm...how would more traction lose you ET? Am I missing something?
Old Aug 28, 2003 | 11:31 PM
CashDudeHomie's Avatar
That is However lower gear ratios supposedly use up a couple rwhp but you would still run faster et.
Old Aug 29, 2003 | 02:29 AM
sleepersilverado's Avatar
possibly because they were making just enough power to barely spin the one wheel peel. therefore not letting the motor bog. so now they dont make enough power and have more traction making the motor bog resulting in a slower et. just a thought.
Old Aug 29, 2003 | 03:03 AM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Yea, what he said.
I love my new Eaton. I can stomp it, and it will hook up and go
Old Aug 29, 2003 | 06:16 AM
FILE's Avatar
Its the other way around. You will be a couple tenths faster becasue of better traction.
Old Aug 29, 2003 | 07:35 AM
No way, unless something is done wrong. Mine hooks up so much better, I couldn't see how it could not work better.
Old Aug 30, 2003 | 12:21 AM
EricB's Avatar
Oh well, i am still running slow times with my 25 inch tires. Ran 15.54 @ 87.55.
USMCvet0311
Aug 1, 2015 07:45 AM
Dezert1500
Jul 30, 2015 02:51 PM
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
Ammadien
Jul 22, 2015 08:50 PM
