Install kit for Eaton posi and gear?
Old Aug 7, 2002 | 09:20 PM
BigJ's Avatar
Default Install kit for Eaton posi and gear?
Anyone know if an install kit is needed to install a posi and gear? I know the carrier bearing has to be changed, but can I reuse everything else, or do I have to buy an install kit?
Thanks
Old Aug 7, 2002 | 09:29 PM
oxidizr's Avatar
Moderator / Sponsor
Default Re: Install kit for Eaton posi and gear?
You should get the installation kit...New crushe sleeve, carrier bearing shimms, carrier bearings and pinion bearings.
Richard
Old Aug 9, 2002 | 11:49 AM
BigJ's Avatar
Ok, I have the 8.6 rearend from the factory, I am putting in a 8.5 ring and pinion, and a 8.5 posi. Which carrier bearing and pininon bearing do I need? 8.6 or 8.5? This is going in tommorrow, so any help would be appreciated.
Thanks
Old Aug 14, 2002 | 07:22 PM
brown's Avatar
I just bought my truck and its a one leger !!!how much will it cost to make into a true posi and what parts are involved? and can u recomend and places to buy it? thanks much apprictaed <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Aug 14, 2002 | 07:23 PM
brown's Avatar
I just bought my truck and its a one leger !!!but I am keeping the stock 373 gearing,How much will it cost to make into a true posi and what parts are involved? and can u recomend and places to buy it? thanks much appricated <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
<small>[ August 14, 2002, 07:25 PM: Message edited by: brown ]</small>
Old Aug 14, 2002 | 09:33 PM
BigJ's Avatar
I got a new Eaton posi off of Ebay for under 250 shipped. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Gotta love that! They run around 450 from most shops. Gears will run about 150-200 just depends on brand and size. Install kits (depending on which one you get) will cost 50-150 for everything.
I don't think you will be able to use your stock gears because they are the 8.6 All posi units that I have seen come in 8.5, so I am almost certain that a 8.5 ring and pinion must be used. Someone verify this please.
I still need an answer to my previous question, if anyone knows.
Old Aug 14, 2002 | 09:50 PM
The factory gears will work with it. It's still an 8.5 rearend. I've used my stock gear and an aftermarket no problem. Also don't forget to use the Motorcraft Friction Modifier additive to mix with your gear oil. You can get it at the dealer or some parts houses.It will keep it from chattering. GOOD LUCK!!! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Aug 15, 2002 | 07:02 AM
I would not by the kit unless your truck has alot of miles. Just put it together the way it comes apart and no problems use the shims where they came off the old set up...no sweat... <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
________
Lovely Wendie99
Choda
Jan 22, 2026 02:03 PM
LCHEE
Oct 24, 2020 04:10 PM
1slwgto
Aug 16, 2015 06:40 PM
iregret
Jul 27, 2015 10:31 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
