Inline fuel pump ??? what wire you guys tapping
Old Jul 13, 2008 | 09:48 AM
dewmanshu's Avatar
Moderately Differentiated
Ok, so it will opp like the stocker, but the stocker still will operate while the big one ops to correct..
Christ if I knew it was all this I would have put a intank pump in it..
John
LOL, then you would of done an inline later. LOL I have the 255 in tank and inline.
Sorry Dirt, I knew you would of done it right, but you didn't say it so I just wanted to make sure it's "out there".
Yes both pumps need to run. NO way is that stocker pushing thru that inline when it's not running. OKay it will be but you'll notice you have an issue. If you have run your wires yet, I suggest running 10 ga wire, you will NEVER doubt the feed.
Old Jul 16, 2008 | 08:26 AM
Dirty 30's Avatar
LS1Tech Whore
I got a question. To connect my inline fuel pump, I simply used the factory + and - wires to connect it. Would that be a problem? It has been working fine, except that when driving the fuel pressure reading jumps around like crazy between 45 and 60 psi. Could it be the way i wired it or is it probably leaking somewhere?
Old Jul 16, 2008 | 08:30 AM
Dirty 30's Avatar
LS1Tech Whore
BTW, im using a Vette fuel filter w/built in fuel pressure regulator. When it was new (just 5,000 old) it was doing great, fuel pressure was at 58psi all the time with out the gauge bouncing like crazy.
Old Jul 16, 2008 | 09:01 AM
dewmanshu's Avatar
so, you "T tapped" the factory pump wires? You are feeding the pump with the same wires the factory pump is being fed with? Yes, that would be a problem. The wires aren't big enough.
Old Jul 16, 2008 | 09:05 AM
dewmanshu's Avatar
take those wires off the inline pump terminals and put them on the #85 and #86 of a relay (it doesn't matter which is which for grnd or positive). Then give your inline pump a real good ground. #12AWG at least. Then Run a fused wire from battery power to the #30 on the relay. Then run a #12AWG at least from #87 on the relay to your positive terminal of the inline fuel pump.
Old Jul 16, 2008 | 01:42 PM
Dirty 30's Avatar
LS1Tech Whore
No, i dont have a factory fuel pump anymore. Its a 10 gallon fuel cell with just an inline walbro/holley 480 pph.
http://www.jegs.com/i/Holley/510/12-...754836%7C10307
Old Jul 16, 2008 | 03:18 PM
dewmanshu's Avatar
If that's the only pump you have, I'd probably do a hot wire kit. Replace stock wires with larger wires, it should help considerably (or prevent a future issue) You have a regulator? If the pressure is pulsing like that I'd check that as well.
Old Jul 16, 2008 | 03:58 PM
Dirty 30's Avatar
LS1Tech Whore
its a vette fuel filter with built in regulator at 58psi, yep only pump
5.3Okasai
Mar 9, 2022 01:07 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
wrb002
Aug 31, 2015 12:00 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
