injectors??
Old Mar 3, 2005 | 08:03 PM
GMC_Matt's Avatar
Default injectors??
Hey guys,
I have just installed a procharger on my 2002 gmc sierra 1500 with a 5.3
procharger claims that with there fuel management setup and the pump in the kit, that the stock injectors would be fine. However I run into a lean condition whenever I go past 6 psi of boost.(even with the injector on time running at +5% using my Diablo sport) The charger I got is good for 9 psi but I just don't want to put the pedal to the floor when I see it running lean at 6. I am wondering if anyone has put one of there kits on their truck, or if you could tell me where I could find some bigger injectors for my truck.
Thanks,
Matt
Old Mar 3, 2005 | 08:17 PM
Wilde Racing's Avatar
How do I change this text
Racetronix has some 44lb/hr direct fit injectors.
Old Mar 3, 2005 | 09:02 PM
KLUG'S SS's Avatar
FormerVendor
Get rid of that FMU and get some 43lb's and a custom tune and you will be alot better off.
Old Mar 4, 2005 | 09:43 AM
Chevmann99's Avatar
That's what I did, much happier........ I also had to swap out to a different inline pump, the ProCharger pump could not keep up with the bigger injectors.
Multec 43Lb injectors
Walbro External GSL392 fuel pump
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
