Injector stock size
Old Mar 28, 2006 | 11:51 PM
99LoweredSierra's Avatar
Default Injector stock size
What is stock injector size?
Old Mar 29, 2006 | 12:37 AM
adrenalinep's Avatar
I think 99-00 have 16lbs 01-up 24lbs
Old Mar 29, 2006 | 11:01 AM
BigTex's Avatar
1999 (4.8 and 5.3) is 21.x pounds. 2000+ is 24.x pounds. Only variation is if the vehicle is set up for flex fueling (which not many are).
Old Mar 30, 2006 | 01:49 PM
Will one from a 02 SS fit my 99 Sierra?? They are 28.lbs Thanks
Old Mar 30, 2006 | 01:51 PM
ktmrider's Avatar
They will work but require modification to fit on the fuel rail and the connector.
Lots of posts regarding the mod, else Richard will post for the Nth time...
Old Mar 30, 2006 | 02:48 PM
ZR1 DREAMING's Avatar
Camaro SS? if so, you will need to slightly modify to fit as stated above. But the first year of the Silverado SS was 2003 if that's what you were asking and I don't believe they are different.
Old Mar 30, 2006 | 02:55 PM
No the camaro SS sorry
Old Mar 30, 2006 | 05:15 PM
BigTex's Avatar
HA! Good one. Search feature is your friend (when its working ).
I ran some Fbody injectors in my 99 truck for a while.
Old Mar 30, 2006 | 08:42 PM
So they worked ok then?
Old Mar 30, 2006 | 09:41 PM
Quik's Avatar
5 year bitches!
i run svo injectors on my truck but also have vette fuel rail
FlowmasterMufflers
Jul 30, 2015 05:03 PM
lxcoupe
Jul 21, 2015 02:12 AM
GMCtrk
Jul 17, 2015 06:39 PM
gavin2005
Jul 16, 2015 12:09 AM
jrplz
Jul 9, 2015 12:07 AM
