Injector questions
Old Sep 3, 2006 | 06:10 AM
Faze2183's Avatar
Question Injector questions
ok i was screwing around with this srt10 the other night and ya he pulled me at top end. but something i noticed was it felt like i was bogging down or something or running out of fuel but yet i had a full tank of gas...
my question is i heard from someone you can use the E85 injectors as a quick upgrade from the stockers; is this correct?
or would it just be better to upgrade to the Delphi 42lb injectors???
Old Sep 3, 2006 | 08:18 PM
Faze2183's Avatar
WOW 14 veiws and not an answer?
Old Sep 3, 2006 | 08:29 PM
99LoweredSierra's Avatar
I wouldn't think they would be at full cycle with the mods you got? Maybe try cleaning them or running some injector cleaner through it.
Old Sep 3, 2006 | 08:50 PM
kbracing96's Avatar
You shouldn't be out of injector with your mods. If you wanted to upgrade injectors, your best bet would be some injector form a 8.1 truck. There 31 lbs/hr, where your stock ones are 24lbs/hr and they are a direct swap physically, but do REQUIRE an adjustment to the tune be for running them. Flex fuel injectors are 33lbs/hr, but they have a different plug on them, but you should still be fine with the stockers.
Old Sep 3, 2006 | 10:34 PM
Faze2183's Avatar
i run nothing but 93 octane as well as some lucas fuel injector cleaner every other fill up...
what should i expect from the 8.1 injectors vs my stockers?? whats the diffrence between the 8.1 marine version and the reg 8.1 injectors?
thanks for your responces...
part number please!!!
Old Sep 7, 2006 | 10:28 AM
THE-HOE's Avatar
i would like to get my hands on some of these, where can i find them?
5.3lSilverado
25
Aug 29, 2016 12:48 AM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
blackdc3
Jul 7, 2015 07:52 PM
