Im Stumped
Old Aug 4, 2007 | 11:51 AM
ChevyMan23's Avatar
Default Im Stumped
Ok..so you all know about my misfire....its the number 7 cylinder and pissin me off. Iv replaced the plugs with the AC Delco replacements and the wires with MSD's...im still getting a misfire from that cylinder...what else do I need to look at?...my coils?..will a coil from a 2000 5.3 work on my 04?...jus to test...do i need to put my stock PCM back in?...iv had a tuned PCM for around 2 years and no known problems til now..cant be that can it?....all this BS started when i got that tank of bad gas....any help or just ideas would be great....TIA
Old Aug 4, 2007 | 12:00 PM
99Silver6.0's Avatar
Move your coils around. See if the misfire follows. They maybe after a few other things you can look at coil drivers/PCM.
Old Aug 4, 2007 | 12:05 PM
Grumpy5.3's Avatar
I bet you have crap built up in your fuel rail from the bad gas. we see it all the time from bad gas, #7 is where all the crap ends up, clogging the injector and causing a misfire!!!
Old Aug 4, 2007 | 12:22 PM
Fogle07's Avatar
prob. not in your ignition system at all.
Old Aug 4, 2007 | 01:08 PM
budhayes3's Avatar
PT's Slowest Truck
I've heard that injector failures, especially #7, are somewhat common.
Old Aug 4, 2007 | 04:17 PM
ChevyMan23's Avatar
How hard is to move coils like that in case it is that?..How hard is to to remove injectors? and what do ya do to clean them?..Iv never messed with those....Thanks for the ideas
ARC
57
Feb 21, 2022 10:54 AM
black03rcsb
Sep 1, 2015 10:17 AM
Lostinmiself
Aug 28, 2015 06:30 PM
05GMC4.8
Aug 7, 2015 09:55 PM
dirt track racer 81
Aug 23, 2007 01:18 PM
