I'm getting an ABS and BRAKE warnings lights
Old May 26, 2006 | 12:18 AM
ss1le02's Avatar
Default I'm getting an ABS and BRAKE warnings lights
They've come on two times in the last week and a half, both ABS and BRAKE warning lights. They appeared when I started the truck up. I don't see any fluid around the wheels, and the brake resevoir is full. What gives?
Old May 26, 2006 | 01:44 AM
4.8redchev's Avatar
check your fuses make sure there in. also are the brakes acting funny? i had a wheel senor go out in the front left hub so my brake would lock comming up to stop.
Old May 26, 2006 | 02:28 AM
Both of mine came on one day and the ABS pump ran constantly. I had to pull the ABS fuse to stop the pump but the lights are on, I guess its time to buy a new ABS module.
Old May 26, 2006 | 06:13 AM
Grumpy5.3's Avatar
Default abs
you are correct sir you need the ab module, but just the electrical part of it!!!
Old May 26, 2006 | 06:34 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I had similar trouble accompanied with a funny grinding feel to the pedal under certain circumstances... L front wheel bearing.
Old May 26, 2006 | 07:35 AM
joehawkz71's Avatar
i belive that there is a recall out on this! the ABS sensor has something wrong with it that they have to replace them!! or something like that...i have the recall at my house so ill check it when i get home from work!!!
Old May 26, 2006 | 09:10 AM
Colby 04's Avatar
That didn't happen to start around the time of your gear or tire size change did it????
Just FYI, I had ABS and Brake warning lights every 3rd start up right after my gear change. It's actually a "wheel speed sensor mismatch" code. Replacing the module or any other ABS parts will do nothing for it. The speedometer was calibrated and the lights never have come back on
Old May 26, 2006 | 08:20 PM
Grumpy5.3's Avatar
Default recall
all that is done for the recall is clean the rust from around the wheel speed sensor, and applying some anticorrosion paint to the sensor mounting surface... Like colby said if you changed gears, you have a mismatch in the wheelspeeds causing your light...
Old May 26, 2006 | 08:27 PM
BradS's Avatar
https://www.performancetrucks.net/fo...d.php?t=364321
This should help you out. Plus check ya PMs
Old May 26, 2006 | 09:05 PM
litreddevil's Avatar
Banned
grumpy is correct u just need the electrical part of it not the whole thing
