IAT's with Radix
Old Jun 19, 2005 | 09:51 PM
  #31
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by zippy
i'd like to get some time to work on the same method ford used in their prototype with running the a/c through the intercooler. i think that would make for some impressive numbers.
Been there done that, have the t-shirt....not worth the work IMO.
Old Jun 19, 2005 | 09:56 PM
  #32
Lone Chev's Avatar
seems like running the A/C compresser to make horsepower kind of defeats the purpose but I believe that ford had it working pretty well.
Old Jun 19, 2005 | 09:57 PM
  #33
BlownChevy's Avatar
blownerator
25 Year Member
The A/C turns off at WOT......The A/C is used to cool the water in another res. tank. It works, but the cost/gain is not worth the effort.
Old Jun 19, 2005 | 10:04 PM
  #34
Lone Chev's Avatar
Well Zippy might be like me... More time than $$$$......Zippy "build it and they will come"
Old Jun 20, 2005 | 12:13 AM
  #35
zippy's Avatar
i was thinking of running the 134A through the intercooler just as you would an evaporator inside the car.
Old Jun 20, 2005 | 01:03 AM
  #36
Flyer's Avatar
I'm with BigTex ... those are about the temps I see with mine. I've also got the old original heat exchanger up front and could REALLY use a nice bigger one. I think it would be worth some time too. I see no KR though. I very seldomly see any KR, even in high heat with the sun beating down.
Old Jun 20, 2005 | 02:13 AM
  #37
onyx's Avatar
14 Second Truck Club
Originally Posted by Crash Dummy
Most likely wouldn't even help My IAT never went over 135 last night, about a 110-125 average. 160 is when you need to start doing something about it, that is about the temp the fuel stars to evaperate and cause power loss.
crap..
went logging today and found that my avergae was 160... got as hot as 194 at one point and as low as 142...
of course it was about 110 degrees today.
maybe its time to check the ol reservoir.
Old Jun 20, 2005 | 06:30 AM
  #38
wkdivr's Avatar
Another idea. What about that Zex system called "Ejector Air Amplifier"? I don't know if it would even work on a FI system, but it's a thought.
Old Jun 21, 2005 | 12:07 AM
  #39
onyx's Avatar
Originally Posted by onyx
crap..
so is this bad?
Old Jun 21, 2005 | 06:19 AM
  #40
wkdivr's Avatar
I Would think under hard acceleration you'd want your iat's to be in the 120-140 range. I noticed mine to be around 146 thru the traps. Ultimately, I'd like to see them in the 120 range. There's lot's of differing opinions on this subject. Some say you can spray a 50 shot of nitrous thru the maf, and it brings the temps down by 40 degrees. I spoke with Rodger Vinci about this yesterday, and he advises the best way to achieve lower iat's without being on the ragged edge tunewise, would to put a second heat exchanger inline in the system with a fan on it. I have the heat exchanger mounted in the lower valance, so I think I might just put another ezchanger in the original Radix spot, in front of the radiator. Maybe something like an aftermarket trans cooler with fan. Also going to slow down the intercooler pump to around 10-12 volts, like the guys from Chevyhighperformance did.
