IACV issue?
Old Nov 6, 2018 | 06:47 PM
Slader Roberts's Avatar
Registered User
Default IACV issue?
Hey guys new to the forums. Just bought a truck here in Austin TX. 2001 Chevy, Single Cab, 4.8 vortec, Manual transmission, Stepside. Great clean truck. One issue so far is the truck will hold rpms when letting off the throttle in gear... and sometimes free revving it will stick and rev up to 3,000 rpm on its own and hold for 4 to 5 seconds then slowly drop to idle. I checked the TB and IACV. Replaced the IACV and the truck ran MUCH worse(stalling, holding rpms) so I put the old one back in. Is there a teach in process for a new IACV? Really would like to drive the truck with rpms not sticking on decel. TB cable is also fine.
Old Nov 6, 2018 | 08:59 PM
Jutsumguy's Avatar
Default ?
Have u checked the tps
Old Nov 6, 2018 | 09:08 PM
Registered User
I checked operation with a scan tool just 0% to 100% pedal travel.
Old Nov 7, 2018 | 05:15 PM
PFIX's Avatar
You can do a relearn by disconnecting the negative battery cable. Reconnect the cable and with the engine at normal operating temperature let engine idle for 5 min. Turn off the key and restart.
Also check to ensure your throttle is closing all the way onto the throttle stop at all temps. Your TPS should be reading about .5 volts when at closed throttle. This should be a yellow wire at the TPS connector that is the output signal to ECM.
Do you have an aftermarket throttle body or stock? Are there any faults stored in the ECM?
Old Nov 7, 2018 | 05:42 PM
Registered User
Thank you!! It is the stock throttle body.
Old Nov 20, 2018 | 10:28 AM
axekick's Avatar
Do you know if it's ever been tuned?
Old Nov 20, 2018 | 03:50 PM
Last Call's Avatar
TOTM: January 2007
I've had bad luck with new but aftermarket IAC valves. I only use AC Delco, and never had an issue. A few ideas:
Reset the TPS, disconnect [plug at TPS sensor, ignition on for 15 seconds, off, then reconnect. That should zero out the TPS percentage reading in the PCM.
It would not be a bad idea to check for a vacuum leak somewhere.
And it would be good to see if the PCM has been tuned, that can also be the culprit.
Old Nov 20, 2018 | 06:13 PM
RedXray's Avatar
100% Redneck
If it's the "cracker" settings in HP Tuners... when you push in the clutch the idle will hang at like somewhere around 1200 to 1500 until you come to a complete stop, then the engine drops to the commanded idle set in the tune. That can be tweaked in the cracker settings (but 3000 rpm it's probably something else). Just something to look at after any relearn and sensor replacements fails to work. It could also be a worn or damaged throttle body itself causing the throttle blade to stick on the housing. If all fails just replace the TB with a used one from the J/Y.
I found a new (New Old Stock) ACDelco on ebay with sensors, still in the beat up box, for my truck, $75 shipped
stoicho315
Feb 3, 2014 08:47 PM
1999stepside
Jun 4, 2003 09:50 PM
Snake Eater
Mar 20, 2003 05:54 PM
ZBass28
Nov 28, 2001 05:09 PM
