I Need Your Help. 408 Stroker Wont Run.
Old Oct 21, 2020 | 03:01 PM
  #21
darkirish63's Avatar
Send the build specs and your PCM to Alvin @ PCM of NC and do a relearn when you get it back. You're tune is jacked.
Old Oct 21, 2020 | 04:10 PM
  #22
00pooterSS's Avatar
Has an engine ran on the tune that is currently on it? Any engine?
Even if it was a stock tune it should run and not bang like that.
Old Oct 21, 2020 | 05:19 PM
  #23
That popping sounds a lot like cracked, broken plugs. Silly question but, where the sparkplugs in when you put the headers on?
Old Oct 21, 2020 | 07:02 PM
  #24
DrocheGMC's Avatar
Originally Posted by dantheman1540
Hurry up and get it running then post more pics, strokers are cool and so are trucks with 99-02 HD front ends.
ahaha I am doing my best!
Old Oct 21, 2020 | 07:06 PM
  #25
DrocheGMC's Avatar
If it is tune related I would like to give BB a chance but if i do find it to be a continuous issue I will look into sending the PCM to Alvin. I take it he is a tuner?
Old Oct 21, 2020 | 07:08 PM
  #26
DrocheGMC's Avatar
As far as I know it is a completely new tune built around my engine specs. I have never personally used this tune.
Old Oct 21, 2020 | 07:11 PM
  #27
DrocheGMC's Avatar
I have put two sets of new plugs in, both sets were installed after the headers and they do not appear to be broken in any way.
Old Oct 21, 2020 | 10:13 PM
  #28
dantheman1540's Avatar
Good suggestion I destroyed a couple plugs while installing headers by myself.
Old Oct 21, 2020 | 11:14 PM
  #29
DrocheGMC's Avatar
ahahaha I learned the hard way on my first engine build with this truck as well! It’s weird how much plugs misfire without the porcelain😂
Old Oct 22, 2020 | 09:17 AM
  #30
He is that and more. His shop specializes in GM builds. I've used him exclusively for my last two tunes during different builds and while no mail order tune will be perfect, he's always on target.
