I disabled all of the injectors and went cylinder by cylinder based of your suggestions. 1-7 sounded great, but found an issue with 2 & 8. Turns out when I fixed the initial coil pack ground, and changed the plugs I flipped the passenger side coil pack harness🤦🏻♂️🤦🏻♂️🤦🏻♂️.
i checked it multiple times but apparently the more you mess with something the more you actually mess it up 😂😂.
I am glad it is running and can’t thank you enough for all of the help and ideas!!
Here are some build pictures as well. The engine bay is not finished, there is a lot of tidying up to do, I just was to anxious and wanted to start the motor ahaha.
Also does anyone have suggestions on a CAI for the Holley High Ram?
