i know this has been discussed before
Old Jul 6, 2008 | 04:18 AM
bigbegum's Avatar
Default i know this has been discussed before
i know you are sick of newbies asking but I cant find what I am really looking for. I have an 01 sierra 1500 extended cab. I am in the process of installing an lq4/4l80 pullout from a 04 2500.
Seems like there are a few minor differences in the two harnesses. looks like the primary o2 sensor plugs are different and the cooler lines. maybe some other things I cant remember right now.
Can someone point me out a good thread(s) to go over. Seems like most people are just swapping long blocks.
Do these computers have a vats system? Will i run into any interface problems with the lq4 harness and ecu with my 1500?
I have 243 heads and a ls6 cam in my 5.3, what will the compression on the lq4 be with 243 heads if I decide to swap them?
thanks for pointing me in the right direction.. time to let the neighbors get some sleep.
Old Jul 6, 2008 | 08:01 AM
v8
17,16,15,14,13,12,11 Drvr
your compression on the lq4 will be 9.5.1, right now on the 5.3 your at 9.0.1 or close if your using the 243 heads built for a 5.7 or 6.0
if there the newer 243 heads on the 07 up trucks then your at 9.5.1 or close, and if you put them on a 6.0 then it would go up maybe to 10.0.1
the trans and harness are different look at the sponser list over here--------------->
finish line trans or maybe a few others have what you need you will also need a new bracket to hold trans.
https://www.performancetrucks.net/fo...highlight=4l80
your search at the top is your friend heheee, just type in 4l80 and it pullls up alot good luck.
Old Jul 6, 2008 | 08:32 AM
nonnieselman's Avatar
What i did.. and i suggest this..
Wiring harness is a easy one.. Swap the White and Brown wire on the transmisison connector. Add 2 wires to the PCM from the Front VSS.
https://www.performancetrucks.net/fo...d.php?t=413157
Remove intake manifold off of LQ4, Replace it with your current Intake.
Swap any Sensors to fit your current Harness (only sensor i had to swap was the oil pressure).
Modify your crossmember or buy the conversion xmember.
Get it tuned for the 6.0/80E.
Theres no point in tryin to use the 6.0/80E harness, just use your current one.
PM me if you need some more help, this is a easy swap.
I replaced my 2000 5.3/60E with a 2004 LQ4/80E.
Lamartian92
Sep 10, 2015 09:27 PM
carid
Sep 10, 2015 09:07 AM
lxcoupe
Aug 24, 2015 08:16 PM
Lamartian92
Aug 21, 2015 01:43 PM
