I hit the 60k mark the other day
Old Apr 7, 2004 | 12:42 PM
Default I hit the 60k mark the other day
So what should I do other then the scheduled maintenance in the book? I can do most of the things my self.. But I'm wondering if the tranny should be looked over, or perhaps the suspension looked over as I've noticed a popping sound on slow speed turning.
Old Apr 7, 2004 | 12:47 PM
LOW2000's Avatar
Grease the zerk fittings on your ball joints and anything else on the front end you can find.
Run a bottle of chevron techron fuel system cleaner or Gumout Regane to keep your injectors and cylinders nice n clean.
Check your PS fluid level.
Make sure your swaybar endlinks are still tight, i've had the lower bolt drop off before and there was nothing holding one end of my swaybar.
5.3Vortec's Avatar
Banned
I have the poppin too, just in the driver front when turnin left.
Old Apr 7, 2004 | 01:29 PM
Hit Man X's Avatar
Drain and fill rear diff. Tranny fluid. PCV. Fuel filter.
Old Apr 7, 2004 | 03:47 PM
Clean the injectors with some N2O. j/k
I think everyone said it right. Just remember that if you have the G-80 rear you need the limited slip additive. Dont want to forget that. Maybe check the O2s if your really board.
Old Apr 7, 2004 | 03:49 PM
That popping may also be your front CV joints if you have a 4x4. Be sure to check it out.
Old Apr 7, 2004 | 05:34 PM
Thanks guys! What would I do without you
01silvy
Sep 26, 2015 10:20 PM
BlackGMC
Sep 21, 2015 01:48 PM
69z-28
Sep 21, 2015 07:31 AM
old motorhead
Sep 18, 2015 03:33 PM
11MPG
Sep 8, 2015 04:52 AM
