HPTuners, How do you remove line pressure from a 4l60e after transgo?
Old Feb 8, 2005 | 07:56 PM
moregrip's Avatar
what a rush!
Default HPTuners, How do you remove line pressure from a 4l60e after transgo?
I'm almost positive that after you install the transgo shiftkit it recommends to remove any added line pressure built into a tune or maybe even a little extra over stock.
What is the standard and how is it done thru HPTuners?
Old Feb 8, 2005 | 08:05 PM
ZDEN's Avatar
base shift pressure vs torque vs gear table under a4 shift properties. you can lower the whole table by a percentage or lower one end for lighter shifts at low rpm and harder shifts at high rpm
Old Feb 8, 2005 | 08:11 PM
moregrip's Avatar
what a rush!
what is the preferred way?
do you use the edit single value?
Old Feb 8, 2005 | 08:26 PM
ZDEN's Avatar
i raised mine the same way the predator does i just added 25% acroos the table for 1-2 shift, 15% for 2-3 and none for 3-4. i have a transgo hd on the way, when i get it installed i'm going to play with the table to keep my shifts fairly soft down low and hard at wot. any way you can just lower it 5% at a time till you like it.
Old Feb 8, 2005 | 08:34 PM
moregrip's Avatar
what a rush!
for instance, I click 1-2 shift, the entire row is highlighted, what exactly do I do next to lower that rows values by 5%?
btw, thanks for the help
Old Feb 8, 2005 | 09:00 PM
ZDEN's Avatar
after selecting 1-2 row -select times- enter .95 -commit-save changes. remember to write down what you change so you don't forget.
Old Feb 8, 2005 | 10:12 PM
zippy's Avatar
the best way to do that are to get a copy of stock trans tables. leave the rest of the tune as you want and bring the pressure settings back to stock. from there you can modify shift timings, shift points, etc. deffinitly the best was for that is to start with the stock...
Old Feb 8, 2005 | 11:43 PM
moregrip's Avatar
what a rush!
thanks fellas!
and thanks once again flyer for being so patient and leading a horse to water!
zblee
63
Jun 10, 2023 01:25 PM
Ferocity02
Aug 7, 2015 08:50 PM
oharajo
Jul 18, 2015 09:24 PM
GMCtrk
Jul 17, 2015 06:39 PM
1320Chicken
Jul 14, 2015 10:58 PM
