How to order a custom grind cam?
Old May 9, 2008 | 06:01 PM
00ChevyScott's Avatar
Wearin' da big hat
Default How to order a custom grind cam?
I want a Comp cam 212/218 but on a 112 lsa instead of a 115 lsa. How do I order a custom grind? Do I have to go through a shop or can i get a decent price straight through comp. And by decent price I mean 375 - 400 range.
Unless someone can suggest me a better cam on a 112 lsa? Ive also been considering a TR220
Old May 9, 2008 | 06:08 PM
LMSeven's Avatar
I'm pretty sure Thunder Racing does custom grinding for a bit over $400.
Old May 9, 2008 | 06:25 PM
chevyguy7802's Avatar
I payed about 420.00 for mine thru comp......only suck part is waiting on the line for 30 mins lol.......
Old May 9, 2008 | 06:38 PM
99Silver6.0's Avatar
Look in the Comp catalog or on the net... Get your lobe numbers, call up and give them the numbers.
Old May 11, 2008 | 12:08 AM
Wearin' da big hat
What are some good cams on a 112lsa that are between the 212-220 range?
Old May 11, 2008 | 12:55 AM
InchUp's Avatar
Here's a better question, in my opinion; what's wrong with 115 LSA?
Old May 11, 2008 | 12:57 AM
Wearin' da big hat
I want the hard lope a 112 has.
Old May 11, 2008 | 01:02 AM
BlackGMC's Avatar
Resident Retard
http://www.texas-speed.com/shop/item...d=898&catid=44
choose the XE lobes
212 .558
218 .563
112 LSA
110 ICL
I believe both the low and high lift versions of that cam are either 114+2 (low lift) and 15+2 (high lift)
Old May 11, 2008 | 01:21 AM
Wearin' da big hat
Whats the differences with the high lift vs low lift?
Old May 11, 2008 | 01:23 AM
BlackGMC's Avatar
Resident Retard
This should explain...
http://www.compcams.com/technical/Ca...07/172-175.pdf
