How much trans fluid?
Old May 23, 2003 | 04:12 PM
Hit Man X's Avatar
Default How much trans fluid?
Anyone have a number of quarts in a fluid and filter change on a 4L60E w/ 4x4 pan? I am thinking around 7 qts or so...
Thanks!
Old May 23, 2003 | 04:23 PM
Wheatley's Avatar
Truck Sponsor
Default Re: How much trans fluid?
should be 5-6 quarts of dexronIII
Old May 24, 2003 | 03:49 AM
LS1TECH Sponsor
should be 5 quarts exactly, it will say in your owners manual, correct me if i'm wrong. Why did you change the filter? i've only changed a few trans filters on 4L60s cause cocking with that filter O ring will only make problems. And trans filters are only called filters cause we have called them that for so long, they are a screen that justs keeps metal filings out of the vavle body. When you turn you car off all the fluid backflushs through the screen into the pan and any metal parts go into the pan.
Old May 24, 2003 | 08:42 AM
Mine hield 5 quarts.I know because I put in 6 and had to remove 1.
Old May 24, 2003 | 02:46 PM
Hit Man X's Avatar
Well I haven't changed anything yet. I need a fluid change, not badly but it is time to do so.
Choda
Jan 22, 2026 02:03 PM
flatblack83
Oct 8, 2015 08:29 AM
1slwgto
Aug 16, 2015 06:40 PM
walledition
Jul 29, 2015 08:54 PM
Suburban2500
Jul 19, 2015 04:50 PM
