how much are the 1 3/4's holding me back
Old Jul 25, 2012 | 10:54 PM
pewterliftedz's Avatar
your truck NEEDS these headers... This is going to be a completely different animal.
Old Jul 26, 2012 | 07:44 AM
Vortec350ss's Avatar
Yea I think those estimates are probably pretty good. Don't change the pulley immediately when you do the other mods, I'm curious what effect they will have on boost.
Thats a pretty damn high compression for boost, it must be snappy as hell down low.
Old Jul 26, 2012 | 06:52 PM
ayousef's Avatar
I have so much power even at idle, even timing fluctuations that are used to keep the idle stable have enough power to make the truck bounce around. So I told my cam guy to kill some low-end and substitute it toward the upper rpms.
Also, with the new heads static compression ratio will drop to 10.6:1 and I am also dropping my dynamic compression ratio with the new cam so it should take 10psi without trouble!
You can say I have the guts to run such a high compression ratio and boost, all on straight 93 octane.
Old Jul 26, 2012 | 07:32 PM
smokeshow's Avatar
Mod with training wheels
That isn't going to help, in fact it will probably make it worse. 'Killing low end' would result in a cam that doesn't idle well because you have less vacuum at idle. More air in the manifold is going to make idle move a lot. You need to decrease idle adaptive timing values, make the ramp rate slower.
Old Jul 26, 2012 | 08:24 PM
ayousef's Avatar
How is that? I'm increasing intake duration and reducing advance ground into the cam BUT I'm also reducing overlap from 4 to possibly 2 or 0 degrees at .050, with that said it will idle much better than my current cam but reduce low end by means of delaying intake closing ABDC.
Also I did lots of changes to adaptive spark not sure if I should reduce it anymore I have a feeling that might not be a good idea but I'm always experimenting
Old Jul 28, 2012 | 09:01 PM
sand man's Avatar
updates ?
Old Jul 28, 2012 | 09:32 PM
ayousef's Avatar
Originally Posted by sand man
updates ?
I ordered the headers, im getting it ceramic coated, ill post pics of the ceramic coating which is INSANE.
Also waiting for my cam guy to spec me a new cam, hes taking forever! Getting the heads from him as well.
Working on the fuel system and Mr Lonnie's performance isnt replying back either...
thats what i call great customer service.
Old Jul 28, 2012 | 11:16 PM
sand man's Avatar
why didnt you go with Fox exhaust shop in Dubai , I hear they make every thing of SS and with your FI 427 I think your motor will like 2" primes.
also, I had tاhe same problem with Lonnie's performance and Emails.
I contacted them for an 800HP fuel system for an 08 yukon denali and it has been 2 months and yet no replay!?
good luck
Oobray
Jun 13, 2022 03:38 AM
ARC
57
Feb 21, 2022 10:54 AM
06 4.8
Jul 14, 2015 08:09 AM
NuckenFuts
Jul 9, 2015 08:45 AM
banker099
Jul 4, 2015 05:50 PM
