how much are the 1 3/4's holding me back
Yea I think those estimates are probably pretty good. Don't change the pulley immediately when you do the other mods, I'm curious what effect they will have on boost.
Thats a pretty damn high compression for boost, it must be snappy as hell down low.
Also, with the new heads static compression ratio will drop to 10.6:1 and I am also dropping my dynamic compression ratio with the new cam so it should take 10psi without trouble!
You can say I have the guts to run such a high compression ratio and boost, all on straight 93 octane.
That isn't going to help, in fact it will probably make it worse. 'Killing low end' would result in a cam that doesn't idle well because you have less vacuum at idle. More air in the manifold is going to make idle move a lot. You need to decrease idle adaptive timing values, make the ramp rate slower.
How is that? I'm increasing intake duration and reducing advance ground into the cam BUT I'm also reducing overlap from 4 to possibly 2 or 0 degrees at .050, with that said it will idle much better than my current cam but reduce low end by means of delaying intake closing ABDC.
Also I did lots of changes to adaptive spark not sure if I should reduce it anymore I have a feeling that might not be a good idea but I'm always experimenting
I ordered the headers, im getting it ceramic coated, ill post pics of the ceramic coating which is INSANE.
Also waiting for my cam guy to spec me a new cam, hes taking forever! Getting the heads from him as well.
Working on the fuel system and Mr Lonnie's performance isnt replying back either...
thats what i call great customer service.
why didnt you go with Fox exhaust shop in Dubai , I hear they make every thing of SS and with your FI 427 I think your motor will like 2" primes.
also, I had tاhe same problem with Lonnie's performance and Emails.
I contacted them for an 800HP fuel system for an 08 yukon denali and it has been 2 months and yet no replay!?
good luck
good luck
ARC
57
Feb 21, 2022 10:54 AM
banker099
Jul 4, 2015 05:50 PM
