how long will trans. last with s/c?
Old Nov 12, 2003 | 04:58 PM
Flyer's Avatar
Originally Posted by yeary01z71
The stock tranny probably won't last long without any torque management if it sees a lot of heavy throttle shifts. I'm getting a custom computer and getting rid of 80% of it and all of it in the abuse mode. But I guess as everyone else is saying, it's depends mostly on how you drive it.
Kyle
I think you have abuse mode and performance mode confused. Abuse mode is when the PCM see's that you are 'abusing' the vehicle and it does some funny things to cut power and make it so you can't be hard on it for a given amount of time.
Performance mode is a tranny table variable. You can make different settings for normal and performance mode like different shift points, tg mgnt options, TCC lock/unlock speeds, etc.
I'm surprised you haven't had any problems David. My tranny started slipping real bad in 1 and 2. The 4l65 only has 5 pinion planetaries over the 4l60. That shouldn't have anything to do with tranny slippage though.
Old Nov 12, 2003 | 05:50 PM
yeary03SS's Avatar
No confusion. I guess I should have said it's getting rid of abuse mode, which uses the torque management to reduce the power.
Old Nov 12, 2003 | 06:34 PM
Hit Man X's Avatar
That's what I thought too but it has:
5 pinion planets
hardened input shaft
hardened output shaft
7 clutch 3-4 clutch pack
better sun gear reaction shell
and some other assorted stuff.
MOBBN
Sep 22, 2015 08:07 PM
Glenn98ZM6
Sep 18, 2015 07:31 PM
lsxperformance
Sep 15, 2015 10:22 PM
06 4.8
Sep 11, 2015 10:36 AM
Mark_k
Sep 7, 2015 10:15 PM
