How high can I go on my shift points w/o any damage?
Old Jul 22, 2003 | 10:27 AM
14 Second Truck Club
Default How high can I go on my shift points w/o any damage?
What shift points is everybody using w/ an aftermarket cam? Doesn't valve float start at or around 6000rpm? Since I put the cam in when I shift at the stock shift points (5200) it pulls real hard like it really wants to go past it.
Old Jul 22, 2003 | 10:41 AM
Flem's Avatar
Default Re: How high can I go on my shift points w/o any damage?
what springs do you have in it? That will determine how high you can go. I wouldn't go over 5700-5800 w/ stock springs. but by the can size I would assume you have done the springs if so 6000 would be safe.
Old Jul 22, 2003 | 11:02 AM
2002 LS6 springs
Old Jul 22, 2003 | 11:16 AM
BigTex's Avatar
With my old LS6 cam and springs, I would shift in the 6100 range.
Old Jul 22, 2003 | 12:05 PM
Did it ever do any damage that you know of?
Old Jul 22, 2003 | 01:10 PM
BigTex's Avatar
Not that I know of. It ran pretty strong for a long time. I will say that after 18 months, the upper rpms didn't have quite the same pull that it had early on. I'd think the 01 LS6 springs were starting to show their age a little and I was getting some valve float. But thats just a guess.
Old Jul 22, 2003 | 01:17 PM
Should I be o.k. considering the 2002 LS6 springs can handle .550+ lift?
Old Jul 22, 2003 | 03:36 PM
Flem's Avatar
remember the 2002 ls-6 heads for which those springs were designed, has lighter valve gear components and @6100 RPM a couple of grams makes a big difference.
ferrellrooster
Mar 6, 2025 03:22 PM
LCHEE
Oct 24, 2020 04:10 PM
1979rs/z28
Sep 23, 2015 08:39 AM
ferrellrooster
Jul 17, 2015 07:07 AM
