How to gut cats without cutting up y-pipe? need hints.
Old Jan 6, 2007 | 12:28 AM
Default How to gut cats without cutting up y-pipe? need hints.
I am planning on gutting my cats tomorrow but I dont want to alter the y-pipe. Anyone have any idea or hints how to do it?
Old Jan 6, 2007 | 10:44 AM
budhayes3's Avatar
PT's Slowest Truck
I have an idea...how about some locking 3/8 or 1/2" extensions, with some u-joints, joined together? Slide the extension into the y-pipe from the manifold flange side and have at it...keep on ramming and smashing (sounds like a bad ****, I know lol). Then use some compressed air and keep blowing out the chunks.
Too bad there's no such thing as a flexible pry-bar.
Old Jan 6, 2007 | 11:00 AM
Country Boy's Avatar
Senior Member
hahahahahahahahahahahahahahaha
Old Jan 6, 2007 | 11:50 AM
Gator's Avatar
maybe a plumbers snake? Get the Benford 1000 and have at it...
Old Jan 6, 2007 | 01:30 PM
litreddevil's Avatar
Banned
we grid the front weld out pull apart beat out the cone and weld back together
Old Jan 6, 2007 | 01:43 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Ram a long extension down into it and get as much as you can out then I would put a wobble on the end of it to beat the rest out. Seem to work pretty well on the old set I had.
Old Jan 6, 2007 | 11:32 PM
Yukon 400's Avatar
you can get a 48" flexible drill extention and a 2 1/2" bi-metal hole saw and have at it.
Old Jan 6, 2007 | 11:46 PM
TURBHOE's Avatar
if you were still up here we could cut and weld like we did mine.
Old Jan 7, 2007 | 03:44 AM
nonnieselman's Avatar
That stuff in the Cats is some nasty and Hard stuff. It took us about 2 hours to take my Y-pipe off and chop the front peice off and get to work with some 3/4" AllThread and 5lb hammer. Then weld them back up...
Dont know of a easy way to do that.
Old Jan 7, 2007 | 02:25 PM
I started throwing a code for B2 S2. Low voltage or something like that. I guess the passanger side cat is bad for sure. I need to get the damn y-pipe loose.
