How to gut cats without cutting up y-pipe? need hints.
Originally Posted by LARRY01Z28
cant you just weld in 2 pieces of straight pipe??
ok i have a question. if i was to gut my cats on my sierra would it run a lot richer. Doesn't the lack of catalytic ceramics inside the cat cause the O2 to read funny and then dump more fuel into your motor? I heard this some where is this wrong or wat. need help.
I finnaly get the y-pipe off with the help of a 1/2" breaker bar. I'm a strong guy and it took several tries with everything I had to break them loose. After a few nonproductive minutes I just went ahead and cut the Y at the cats. The welds are pretty well hidden and smooth aside from the splatter. Damn craftsman welder isnt very adjustable.
With it all mounted back up it sounds AWSOME!!!!! Its is a little louder but has less resonance than before. It sounds mean now, and at highway speed its got alot less drone. Its got a real deep growl. It seems to run alot better to. It takes less gas to get moving and WOT is WAY better. It pulls much harder than I can remember it ever pulling NA. Also its pulling a steady 36lbs. of air and steady 33* timing. It was pulling 32-33lbs before. The O2's were right at 890-900mv. I figured it would run better but damn. The bottom end is noticibly better, mid range is cake, and WOT screams.
Why the hell did I wait a year to do this. LOL
Originally Posted by 4.8T
finally did it huh. i guess you bought a welder like mine. so its not loud in the cab with them off. how much louder did it get? vid time
Its alot quieter than your truck was with the 4" catback. You would love it, its old school kinda mean. No popping on decel either. Its realy amazing how much diff it made. You gotta do it. I had to drop the trans crossmember too.
