How to clean intake manifold?
Old Sep 4, 2004 | 01:47 PM
14 Second Truck Club
Default How to clean intake manifold?
I remember seeing something about this not to long ago. I think one of the local texaco oil changing places around here flushes it with something, can't remember though. I've heard some people saying something about seafoam or something like that?
I took my throttle body off and cleaned all the gunk off of it today and cleaned as far up in the intake as i could. It was like real gunky, oily grime. It has to be hurting the air flow, as well as clogging up my heads over time.
What is the best way to go about this?
Old Sep 4, 2004 | 02:50 PM
TwoFast's Avatar
I want to know as well. my 99 5.3L needs a cleaning.
Old Sep 4, 2004 | 02:57 PM
budhayes3's Avatar
PT's Slowest Truck
I just recently cleaned my top end with 3/4 of a can of Seafoam through the PCV hose. You can use the hose to the power brake booster also. GM Top End Cleaner is good stuff also.
When I worked at the dealership, we used to do a BG induction service that involved 3 cans of additives, 2 through a pressurized fogger nozzle into the throttle body and 1 added to a full tank of gas.
With the way these GenIII engines like to suck oil through the PCV system, a good induction service once a year should be routine maintenance IMO.
Old Sep 4, 2004 | 09:18 PM
one03sierra's Avatar
Formerly one92rs
Talking
i cleaned mine by hand as much as i could get. i looked at it the other day since i installed the catch can and it is still clean. the nos might be helping that out to.
Old Sep 4, 2004 | 11:09 PM
I say get an AMW catch can after you clean it. I will have mine installed in probably a week. Should keep all of that crap out of my intake manifold, and combustion chambers
Old Sep 4, 2004 | 11:11 PM
MacADaYear's Avatar
Or you could make your own catch can for like 30 bucks
Old Sep 4, 2004 | 11:12 PM
I need to get a catch can, just want to really clean it before I put one on it. Where can I get this seafoam/GM Top End Cleaner? How much? Thanks for the info guys!
Old Sep 4, 2004 | 11:20 PM
A catchcan for $30 is not one that I want on my truck. Have you seen AMW's? They are a quality piece.
Seafoam you can buy at any auto parts store. You just start your truck up, and pour some into where your pcv tube goes into your intake. Then you let it run and pour out all sorts of smoke as it cleans the crap out of your intake.
You could also take a can of berrymans B12 with your intake ducting off, and just spray it into your intake(while not running) and just make sure that the red tube doesn't shoot into the back of your manifold
Aaron
Old Sep 5, 2004 | 08:46 AM
Aaron
After I pour the seafoam stuff into the intake, how long do you let it run before shutting it off? Is it a good idea to drive it around?
Old Sep 5, 2004 | 10:30 AM
Formerly one92rs
Talking
hey mac who made there's out of the water seperater and posted pics. that is what i did. i think i payed $19.00 for the seperater. and $10.00 on fittings and hose along with some tie wraps.
