How the Change oil light works..
Old Oct 21, 2006 | 07:25 PM
virgils4.85spd's Avatar
Default How the Change oil light works..
Does the change engine oil go by miles or is there a sensor in the oil that somehow checks the oil and tells when its old????
Thanks,
Derek
Old Oct 21, 2006 | 07:28 PM
LesPaul's Avatar
its based on time and driving habits i think
Old Oct 21, 2006 | 08:18 PM
silver-bullet's Avatar
i don't know but i changed the oil and it is still on. been that way for thew past two oil changes.
Old Oct 21, 2006 | 08:22 PM
BlackGMC's Avatar
Resident Retard
I believe it does it every 6000 miles. To reset it you turn the key on and hold down the gas pedal or you press the gas pedal 3 times and then hold it down till it goes off.
Old Oct 21, 2006 | 08:33 PM
83 Chevy's Avatar
I understood that the computer monitored the engine rpm's and the load (perhaps temperature). You can go a long ways if all you do is highway driving, but you will have to change it often if you are pulling a trailer.
You can reset the oil change meter by turning the ignition to on (not started) and pressing the gas pedal 3 times within 5 seconds.
Mike
Old Oct 21, 2006 | 08:57 PM
SnakeOiler's Avatar
The manual says there are a lot of factors involved, but my experience shows me that mileage plays the largest factor. And the PCM/BCM doesn't know you've changed your oil unless you tell it, by resetting the light.
When I changed my oil every 3K, that's when the light came on - right about 3K miles. Now I change my oil every 6K and that's when the light comes on - right about every 6K.
Old Oct 21, 2006 | 09:43 PM
sroach20's Avatar
i thought it went by engine hours?
Old Oct 21, 2006 | 10:59 PM
Derek @ EDO's Avatar
FormerVendor
its magic!
Old Oct 21, 2006 | 11:01 PM
Dock Rocker's Avatar
Most likely Black magic or voodoo
Old Oct 22, 2006 | 01:42 AM
jakebdb56's Avatar
I think it's be engine hours too. after 3k miles (first oil change) i had 60% life remaining. I forgot how many hours were on the truck then, but at around 5k miles it read 0%
