How the Change oil light works..
I understood that the computer monitored the engine rpm's and the load (perhaps temperature). You can go a long ways if all you do is highway driving, but you will have to change it often if you are pulling a trailer.
You can reset the oil change meter by turning the ignition to on (not started) and pressing the gas pedal 3 times within 5 seconds.
Mike
Mike
The manual says there are a lot of factors involved, but my experience shows me that mileage plays the largest factor. And the PCM/BCM doesn't know you've changed your oil unless you tell it, by resetting the light.
When I changed my oil every 3K, that's when the light came on - right about 3K miles. Now I change my oil every 6K and that's when the light comes on - right about every 6K.
