How to change fuel filter?
Old Aug 11, 2005 | 12:25 AM
14 Second Truck Club
Default How to change fuel filter?
What are the steps in doing this? Thanks!
Old Aug 11, 2005 | 01:02 AM
TXsilverado's Avatar
slide up under the truck and check it out. its pretty self explanitory dont wear your good clothes while doing this because your guna get gas on you.
Old Aug 11, 2005 | 09:33 AM
moes04silverado's Avatar
Default GM new fuel systems
If the the older trucks are anything like the newer ones(03-05), there is no in line fuel filter. GM has come up with this "Maintainence Free Fuel System" ha fun one there. The fuel filter is actually in the fuel cell with the pump. So if you crawl under you chevy on the drivers side just behind the drivers door you may/or may not see it there.
Old Aug 11, 2005 | 10:05 AM
Leroy_454's Avatar
It will be on the drivers side frame rail under the door.
Old Aug 11, 2005 | 11:18 AM
budhayes3's Avatar
PT's Slowest Truck
I can't remember what size the fittings are, but you're gonna wanna use line wrenches to avoid stripping them out.
Old Aug 11, 2005 | 11:36 AM
ngianop's Avatar
Yup, it's wise to use flare nut wrenches on this job - they offer more uniform contact versus a standard open end wrench and should prevent accidental stripping of the relatively softer nuts found on fuel lines. I have an '02 EC and the fuel filter is mounted to the frame beneath the back door on the driver's side.
Good luck.
Oobray
Jun 13, 2022 03:38 AM
thunder550
Oct 8, 2015 04:53 PM
Noah Burns
Sep 7, 2015 05:50 PM
05GMC4.8
Aug 7, 2015 09:55 PM
jrplz
Jul 9, 2015 12:07 AM
