How can I disable the daytime running lights ?
Old Jan 27, 2002 | 03:11 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Default How can I disable the daytime running lights ?
Hey guys, how can the daytime running lights be disabled on a 2002 Silverado LS? Anyone got a link to a tech article or procedure for this? TIA.
James
Old Jan 27, 2002 | 03:37 PM
GREGGO's Avatar
Default Re: How can I disable the daytime running lights ?
On my 2000, you can hit the dome override button 4 times, then it will chime and the auto headlight and daytime running lights will be disabled. Then the headlight switch will work like a regular on/off switch. It will reset every time you turn off the ignition. There is a company called R&D that makes and overide relay for this, but it's like $85 <img src="gr_eek2.gif" border="0"> .
Old Jan 27, 2002 | 11:50 PM
red53gmc's Avatar
Pull the fuse...
Old Jan 28, 2002 | 08:44 AM
GTO Forum Director
[quote]Originally posted by Fast4.8:
<strong>On my 2000, you can hit the dome override button 4 times, then it will chime and the auto headlight and daytime running lights will be disabled. Then the headlight switch will work like a regular on/off switch. It will reset every time you turn off the ignition. There is a company called R&D that makes and overide relay for this, but it's like $85 <img src="gr_eek2.gif" border="0"> .</strong><hr></blockquote>
That's for the "Twilight Sentinel" feature. The auto headlights. Mine only takes twice to shut them off.
To disable the DRL's, simply pull the fuse on GM trucks.
Old Jan 29, 2002 | 12:27 AM
graygmc's Avatar
just take the bulbs out. <img src="gr_stretch.gif" border="0">
stealthperf
34
Feb 14, 2016 11:35 AM
silver-mod-o
Jul 27, 2015 05:24 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
GreyChevy
Jul 7, 2015 08:57 PM
