how big of a block?
Old Aug 1, 2010 | 07:54 PM
scotthughes's Avatar
Banned Scammer
Default how big of a block?
I want to build a 427 stroker next? I know that with a 6.0 you can safely go up to a 417, or that what i heard, i dont know a huge deal about stroker motors, just the basics. But in order to build a 427 stroker, what size block would i need? what size heads? thing like that. thanks for the help
Old Aug 1, 2010 | 08:28 PM
A Low Dime's Avatar
13 Second Truck Club
From what Ive read, most go with and say 414 is the biggest to be used as DD. 418 is the biggest for the block.
Old Aug 1, 2010 | 08:31 PM
brent5631's Avatar
You can get pretty big with an LSX block.
Old Aug 1, 2010 | 08:33 PM
pewterliftedz's Avatar
you can use a 6.2 block.. just get the rotating assembly with a 24x relustor wheel when u order it..
Old Aug 1, 2010 | 09:47 PM
Banned Scammer
thats what i was wondering, about the 6.2 block. so as far as a dayily driver i shouldnt go with a 427? i work on the road, and only drive it about a week out of the month.
Old Aug 1, 2010 | 09:51 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
There is a million ways to get those cubes or close to it. What is your budget? I had a 420 out of lq4 block.
Old Aug 1, 2010 | 09:57 PM
Banned Scammer
well, i mean, i would like to do it right, but also the cheapest way possible. i dont want to go buy an lsx block....if i recall they are pretty pricy. but i dont want to do something that will be a cheap temporary way to get the cubes. i want it tough.
Old Aug 1, 2010 | 11:05 PM
1slow01Z71's Avatar
In short aluminum block for a stroker is the best. Im on my phone so search under my screename for stroker aluminum block words like that and yoou will see a few posts from me about the reasons why. Long strokes especially over4" in an iron block is a bad idea.
Old Aug 2, 2010 | 04:39 AM
Quik's Avatar
5 year bitches!
its going to cost you a fortune to make decent power from a 427. most who go large cubes get average or under par power for a stroker.
ppl usually spend the money on the rotating assembly and budget the rest. this leaves you budget results, then you have ppl who spend the money souly on the topend and make great numbers with smaller motors. a properly built 427 should be well into the high 500 rwhp range but most only see mid to high 400s with their 427s
Old Aug 2, 2010 | 11:42 AM
Link removed check out their tech section or give them a call.
It looks like there doing 400+ ci with the ls3 blocks, but hell i dont think it matters because theyre resleeving 5.3 blocks to achieve the same displacement.
Just my 2 cents.
