Homemade Intake pipe size ?s
Old Nov 6, 2006 | 10:11 AM
BlackGMC's Avatar
Resident Retard
Default Homemade Intake pipe size ?s
What is the size of the pipe need before and after the MAF? I am considering making a new CAI and I need to know the pipe sizes I need to order. I think they are 4in (before MAF) and 3.5in (After MAF). Thanks..
Old Nov 6, 2006 | 12:30 PM
SS_bnoon_SS's Avatar
I know people have built 3.5" and 4" systems all the way through, so either will work. Mine is 3.5" all the way through FWIW.
Old Nov 6, 2006 | 02:04 PM
04BlackGmc's Avatar
10 Second Club
you should be able to make it 4" and do a 4"to3.5 coupler at the maf
Old Nov 6, 2006 | 07:13 PM
jakebdb56's Avatar
what material are you going to use?
Old Nov 6, 2006 | 07:38 PM
BlackGMC's Avatar
Resident Retard
I was wanting to use steel pipe.
Old Nov 6, 2006 | 07:48 PM
jakebdb56's Avatar
you going to weld it yourself are are you going to cut and use rubber elbows?
Old Nov 7, 2006 | 07:52 AM
BlackGMC's Avatar
Resident Retard
Yep I am going to weld it. I was planning on reusing the stock rubber bushings/clamps and using a short 4in radius, 4in steel 90* elbow. There is about 5.5 inches betweent he TB and fan shroud. I am trying to make a UPD type lid out of fiberglass and parts of the stock airbox. I have allready smothed and fiberglassed the bottom side of the airbox and cut a HUGE whole in the back side of it.
I just need to know the OD of the TB and OD of each side of the MAF.
Old Dec 16, 2006 | 12:21 PM
Phantom's Avatar
11 Second Club
so is the throttle body opening 4" or is it smaller?
Old Dec 16, 2006 | 02:08 PM
BlackGMC's Avatar
Resident Retard
I used a 4" elbow if that helps...
Old Dec 17, 2006 | 12:07 AM
Phantom's Avatar
11 Second Club
no way 3" would work huh?
