Here's my new custom CAI
Old Jul 29, 2005 | 07:01 PM
jmproductions's Avatar
Default Here's my new custom CAI
I did a search on here a while ago for "homemade intake" and got some good ideas on how to do a nice intake myself. The parts fit together surprisingly well and I would recommend it to anyone who likes to do a little mild fabrication. The trickiest part was re-routing the upper radiator hose, which requires cutting the neck on the water pump some. My main issue with the name brand kits was excessive cost and I don't think any of their systems are made for a truck without a fan shroud. The airbox was purchased on eBay, the middle pipe and elbow is PVC and the rubber elbow at the TB is from Airflow Systems.
Old Jul 29, 2005 | 08:23 PM
TXsilverado's Avatar
looks nice
Old Jul 29, 2005 | 08:48 PM
jerome's Avatar
looks cleaner than any other homemade system i've seen. doesnt look hacked up or anything. congrats
Old Jul 29, 2005 | 09:18 PM
nativetexan's Avatar
13 Second Truck Club
SSlow 4.8's Avatar
very nice... you got that elbow from Air flow online. com?
Old Jul 29, 2005 | 09:21 PM
Yes, that's correct. It was about $25 shipped.
Old Jul 29, 2005 | 09:41 PM
duwem's Avatar
what did you do to reroute the coolant line, the big one that goes into the t-stat on the top center of the engine is touchin my K&N tube tranfering heat to it, I was thinking some heat shield tape would be a good bandaid, but I really wana just move it some.
Old Jul 29, 2005 | 09:51 PM
The lower radiator hose is the one that goes to the thermostat so I wouldn't think that one would be getting in your way. It was the upper hose that goes from the water pump to the radiator that was the problem for me. I cut down the pipe out of the water pump at least 3 inches then I turned the hose around backwards and cut some off of it and it still touches the intake elbow a little. So I got a piece of neoprene, from a can coozy, and attached it with zip ties to keep heat transfer to a minimum. It worked out pretty well and it should help in your situation also.
Old Jul 29, 2005 | 10:16 PM
litreddevil's Avatar
Banned
looks good did you use the heavy side wall or the thin side wall
Old Jul 29, 2005 | 11:25 PM
It's thinwall. The bigger stuff's outside diameter would not fit well with the rubber pieces.
