HELP Want to go 12.5's or so in a ECSB 4x4
Old Sep 13, 2007 | 08:25 PM
  #71
XLR8NSS's Avatar
Adkoonerstrator
Originally Posted by RandomHero
It's because I got yelled at
Old Sep 13, 2007 | 08:27 PM
  #72
XLR8NSS's Avatar
Adkoonerstrator
I think the bore size advantage goes to the 5.3L over the 6.0L. A smaller bore tends to have better detonation control which is good in FI. The 6.0L advantage is just physical displacement, bigger is better.
Old Sep 13, 2007 | 08:29 PM
  #73
RandomHero's Avatar
Originally Posted by XLR8NSS
I think kbracing96 and WJ MARK have good examples of what ECSB Z71's are capable of with 5.3 and 4.8L engines. They may be slower when stock than a 6.0L SS but, it is not a linear progression when picking up time in the 1/4.
KB
https://www.performancetrucks.net/fo...er.php?u=25675
WJ
https://www.performancetrucks.net/fo...p?userid=66620
Those are pretty good examples there's only a few issues to address....
KB is amazing at fabricating and to my knowledge he does his own tuning. Tuning can cut down 1-2 seconds depending how good you are and being able to fabricate stuff can save you $1000's
The problem with WJ is that he has a great setup, it's just his best time is a 13.7 not a 12.5. Granted his DA is way up there but 1.2 seconds is still a big difference.
Old Sep 13, 2007 | 08:35 PM
  #74
Slow91z's Avatar
DA?? what's that mean??
Old Sep 13, 2007 | 08:37 PM
  #75
XLR8NSS's Avatar
Adkoonerstrator
I wasn't talking about price or fab/tune skills on those, just showing what a ECSB Z71 4.8/5.3L is capable of and how picking up that extra time compared to the 6.0Ls is not that tough.
Running at sea level compared to 8000' DA can make up a LOT of time. I know it doesn't affect turbos as much as NA but, it is still quite a bit. This part is kinda getting side tracked from the original post though.
Slow - Where are you located because altitude plays a role in your track times too.
Old Sep 13, 2007 | 08:40 PM
  #76
nightrunner's Avatar
Mr. Obvious
dumbass
density altitude, its all the weather factors that hurt your et combined together and when your time is corrected using the DA, you get a possible best at sea level
  #77
XLR8NSS's Avatar
Adkoonerstrator
Density Altitude.
Basically a measure of your height above sea level based on your actual altitude and weather conditions. The higher the
DA the worse it is for your times because it means there is less oxygen in the air.
Old Sep 13, 2007 | 08:42 PM
  #78
Slow91z's Avatar
Gotcha, just didn't catch the acronym...I'm in Indiana, and not sure the altitude.
Old Sep 13, 2007 | 08:44 PM
  #79
trever1t's Avatar
2nd fastest 5.3 ECSB
How come you didn't use my truck (ecsb Z71 4x4) as an example of how a 5.3L can shame a larger bore?
Old Sep 13, 2007 | 08:47 PM
  #80
Slow91z's Avatar
Now don't get all butt hurt.
