Electronic Throttle?
Old Apr 12, 2006 | 06:08 PM
Low84's Avatar
Default Electronic Throttle?
Is it possible to swap in an electronic throttle 5.3 engine into an '87 c10. What would be required? Would I have to change the gas pedal?
Old Apr 12, 2006 | 07:52 PM
RoninsDenali's Avatar
Yes, you would need the Gas Pedal, the ETC Control Computer... (A decient sized box, about 3x5 right up against the firewall right next to the fender, drivers side.) As well as a ETC aware PCM and its harness.
Old Apr 12, 2006 | 08:24 PM
Low84's Avatar
Thanks. One more question. Can you change the intake to cable and, still be able to use the same computer?
Old Apr 12, 2006 | 10:21 PM
Yes, from what i can see in my own PCM's software, all the stuff for a Cable operated throttle and IAC controls is still listed. So i am reasonably sure about that.
Old Apr 12, 2006 | 10:56 PM
Low84's Avatar
Thanks alot. Good looking out man.
Old Apr 13, 2006 | 09:44 AM
Is it very hard to put it the electronic throttle? Does it require a lot of custom fabrication? My dad has another C10 with a 5.3 but its not electronic throttle so we are not worried about all the other stuff.
turbo6c3
Oct 5, 2015 06:11 PM
JordanH
Oct 3, 2015 03:59 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Chevy305
Sep 28, 2015 09:21 PM
sTNT971
Sep 26, 2015 04:22 PM
