Help, truck wont start!!!
Old Dec 22, 2005 | 08:40 PM
6.0caddy's Avatar
Default Help, truck wont start!!!
Hey i just put in a LQ9 out of a denali, it was wreaked. It cranks over but that is it. it has a code p0335, which is crankshaft position sensor A circuit malfunction. the thing is i think it was from my old motor. I deleted it, and crank the motor and no code. My question is well the motor start even with that code?
Old Dec 22, 2005 | 08:44 PM
BlownChevy's Avatar
blownerator
25 Year Member
sounds to me like the sensor is either bad or not plugged in. It will not start without it.
Old Dec 22, 2005 | 09:09 PM
treyZ28's Avatar
you need a crankshaft position sensor. without it, your coils and fuel injectors have zero idea when they should be firing
Old Dec 22, 2005 | 09:21 PM
6.0caddy's Avatar
thanks guys well try that.
Old Dec 23, 2005 | 11:11 AM
6.0caddy's Avatar
i put my old one from my 5.3 and still nothing just cranks over? should it run or does the pcm need tune to run? help me!!!!
Old Dec 23, 2005 | 11:15 AM
onebadrubi's Avatar
you have to get a 6.0l tune instead of your 5.3l
Old Dec 23, 2005 | 11:18 AM
BlownChevy's Avatar
blownerator
25 Year Member
nope, it will run fine on the 5.3 calibration. He will eventually want to get it tuned, yes...but it will start, run and drive on the 5.3 cal.
Old Dec 23, 2005 | 11:20 AM
6.0caddy's Avatar
any ideals on what it could be???
Old Dec 23, 2005 | 11:22 AM
6.0caddy's Avatar
i have heard both that it wont and will start. Anyone done the conversion.
Old Dec 23, 2005 | 04:10 PM
blackboostedinfla's Avatar
Do you know what part of the equation is missing. What I mean is spark
or fuel injector pulse also check for compression. The motor should crank up
and run off the old 5.3 tune in your pcm.
