Help, truck wont start!!!
Old Dec 23, 2005 | 04:19 PM
TXsilverado's Avatar
crank position relearn?
Old Dec 23, 2005 | 07:41 PM
budhayes3's Avatar
PT's Slowest Truck
Is it possible that the reluctor ring on the crankshaft, that the crank sensor uses for it's signal, got damaged somehow or came loose? Also, check the wiring to the crank sensor and make sure that it's not open or pinched anywhere.
Old Dec 23, 2005 | 09:13 PM
1SlowHoe's Avatar
Destroyer of Transmissions
If you know somebody that has HP Tuners or EFI Live they can do the crank relearn for you. The 6L will start and run on the 5.3L PCM, I did it. Even after adding a cam to the 6L it still ran ok. There is a sensor somewhere not picking up. Maybe re-check all your ground straps and wiring harnesses. Check for any fuses that could have gotten blown when messing with the battery during removal or install of the engine...
Old Dec 24, 2005 | 09:59 AM
6.0caddy's Avatar
ok thanks guy well see what happens, how did your truck run once you got the conversion done. was it worth the money and time???
Old Dec 24, 2005 | 11:49 AM
1SlowHoe's Avatar
I'll just say after I got the 6L in I found out what it was like to get a Tahoe on 24's sideways. I used to turn the traction control off because I wanted to spin the tires with the 5.3 but couldn't. Now I leave it on so I don't get in a wreck when I punch it.
Old Dec 26, 2005 | 09:47 AM
6.0caddy's Avatar
cool and im in a truck so im going to have some fun
wrb002
Aug 31, 2015 12:00 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
Ketis
Jul 23, 2015 12:37 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
